1 - 18 of 18 Posts
1996 El Dorado
my car has a rough idle when its in drive and your stopped at a lights or like when your going down a drive way but when i switch in to Park its ok again what could make this happen? miss fire?
Plugs & wires are common cause. Especially after having the fuel rail recall done.
Tech Tips section has instructions on how to check it.
1996 El Dorado
Discussion Starter #9
ok i will look in to that tomorrow ... i read the post about it seems to be easy to look at and test.. so maybe that why i am smelling burning fuel/ exhust smell... after an idle...
The '96 was included in the fuel rail recall. Has that been done? If so, it will have a stainless steel fuel rail. If not, it will have a black plastic rail.
1996 El Dorado
Discussion Starter #11
yes it has the stainless steel fuel rail, there was no leak... at all i pulled it out and stuff to see if it was dirty and stuff it wasn't after i did that the idle isnt as bad but still really rough...
Leave the injectors attached to the rail. Lift the rail and injectors as one unit.
1 - 18 of 18 Posts
