I have this irregular shake at idle. It's not a constant 'miss', it's random but frequent and it happens whenever I'm stopped or in Neutral. Goes away if you give it any throttle at all. The ACDelco plugs have about 50K miles. The wires are original at 127K. The FPR isn't leaking and it has been replaced a couple times for hard starting. No codes. Don't see any vacuum leaks. Could it be bad gas or maybe the wires? It disappears completely anywhere off of idle. I hate to throw parts at it. I put some Seafoam in the tank while I try to figure it out. Any suggestions are welcome.
Forgot to mention both crankshaft position sensors were replaced about a year ago for a stalling problem. I'm going to order new wires because they are overdue. This problem came on sudden like. I thought it might be all the rain we are getting but the engine compartment should be dry by now.
