2005 Deville
OK this isn't for a Cadillac and if it's not allowed I'll understand. My dad's 86 Buick Century T Type 3.8 ( 110,000 miles) idles rough in drive but smooth in reverse and neutral. Rough on acceleration smooth at constant speed. Roughness worse when engine warmed up. Has new plugs and wires. Any ideas?
Re: Rough Idle in Drive Smooth in Reverse
'86? :hmm: Did it have a distributorless ignition in '86? If so, maybe a bad coil or ICM.
P.S.
I'll move this to the lounge for lack of a better place.
check the motor mounts -
the engine will lift when in drive and accelerating -
could be a broken/chaffed wire - or bad/loose ground -
2005 Deville
Thanks for the replies. I put the car in drive with the brakes and pressed the accelerator and the motor only rose an inch which I believe is normal so the mounts should be OK? The 3.8 has an ICM and it has been replaced a couple of times in the past so it may be time to change it again. Could a bad EGR valve do this?
If the EGR pintle valve is not seating and leaking, it will cause a rough idle. Open it enough and it will cause a stall. Can't hurt to pull it and clean it.
Cadillac CT6 (2019)
Maybe a transmission mount; the difference between drive and reverse would be opposite torque post-transmission.
