I have an 03 cts 3.6 and it has about 160k mi on it. Recently it has started to idle roughly when I stop at Red lights, and sometimes it will continue after I accelerate again causing a nasty vibration and the occasional blinking check engine light. However if I can manage to turn the car on, go, and keep the rpm up the car will run fine until I have to stop. It also seems like if it's running poorly I can pull over and restart my car and it will start to run smoothly again until the dreaded idle
I had a problem with similar symptoms a year or 2 ago. From what I remember it was a rough idle and similar vibration in acceleration along with the blinking check engine light (it was misfire warnings before and although I haven't checked this time that is what I suspect). I took the car to my mechanic where he found and replaced a bad coil pack. It cost me almost 500 bucks and I know Cadillac parts are expensive and mechanic has to make a living, but being a senior in college I don't have 500 bucks laying around and would also like to learn something if I can.
Now I don't have much experience with fixing cars. I have done a brake job or two on it as well as replacing the alternator, serpentine belt, and tensioner pulley, but that's the extent of my familiarity with the inner workings of this car. Any advice you have, diagnosis, mistakes, parts/brands to search out or to stay away from, ways to prevent it from happening again, resources on video, maybe even a walk through would be much appreciated.
Mike
Mike
