2009 Cadillac CTS-4
Recently I started noticing that when between 1500-2000 RPM (give or take) my engine sometimes stutters and can't hold a stable RPM for a few seconds before it goes back to a smooth, stable value. I checked for any thrown codes when though there wasn't any CEL and found there was originally codes saying there was an engine misfire and misfires on every cylinder. I cleared them and checked later and saw that the misfire codes were back along with codes P0014, P0024, P0011, and P0021. I cleared again and now it only shows P0021, and P0011, so far I've checked and the oil doesn't seem bad, but I've changed all 4 vvt control solenoids only a few months ago and since then I've put less then 10,000 miles on it.
· Super Moderator
2023 CT5-V RWD / 2020 XT6 Sport / 2024 Lyriq AWD (reserved)
Run a mode 6 test on your scanner and look for a misfire count. Share the count here. Could be as simple as bad plugs.
2009 Cadillac CTS-4
When I ran the scan earlier it was saying there was a misfire on cylinders 1 through 6 but I don't know which cylinder is starting it if it's just essentially a chain reaction.
2009 CTS 3.6L DI, 2014 CTS VSport
You'll likely receive more and better help if you make the effort to look up and post the code definitions. I know I don't bother to go look up codes for a problem on somebody else's car. Also post relevant info like relevant repair work (you mentioned VVT solenoids) and mileage.
· Super Moderator
How many per each cylinder? When did you last replace your spark plugs? Do you remember which plugs you used?
