1 - 20 of 27 Posts
2009 CTS4 Premium & 2012 SRX4 Luxury
Re: Rotor/Brake Combo Package
I would not trust off-brand brakes, particularly cross-drilled rotors. Never heard of this Max Advanced brand. Many of those cheap drilled rotors will develop cracks around the holes within a year or two use.
If you want the cross-drilled look without the cracking, have a look at the EBC dimpled rotors and Red Stuff pads.
No way I would purchase an off brand.
Cadillac CTS 2008
Front Brake Replacement Question
I own a 2008 Cadillac CTS and have always taken the vehicle to an authorized Cadillac Dealership for regular maintenance. However, I am aware that it is now coming close to having the front brakes replaced and am trying to save myself some $$$
I have all the required tools to perform a brake change (allen wrench, brake tool and etc) and have always performed my own brake change until purchasing the Cadillac; so my question would be is there any major difference between changing the brakes on a Cadillac vs any other non-luxury vehicle?
I don't want to "assume" that the process and methods are pretty much the same without asking around first. Because if I am forced to spend the extra bucks to have the Dealership do it, I will. As opposed to screwing up things in the effort of saving money.
Any advice is welcome and greatly appreciated!
2008 CTS4 3.6DI (Sold 176k mi) 2015 ESV Luxury Premium
Re: Front Brake Replacement Question
Hey!
It's pretty straightforward just like any other car I've changed brakes on. If anything it's one of the easier ones I've had to change. The rears can give a bit of fight due to the e-brake system integrated into the hub rotors making it hard to slide on and off.
One note the after you take the wheels and calipers the rotor is held on by a single Torx screw. I don't recall the size off the top of my head. But have one of those handy! And of course only if you're changing the rotors also.
'05 CTS-V
Luxury vehicles use disk brakes that are built just the same as disk brakes on economy cars. You're not going to come across any surprises if you do the brake job yourself.
Just make sure of which brake package you have when you order pads.
2016 AWD 2.0T LUXE, 2016 C7 TBDE vert, 2012 911S Cab., 2003 Avey Z66
Changing the pads is a straight forward procedure. The most difficult part is compressing the calipers w/new pads so that you can rotate the caliper back over the rotor. You can even purchase an inexpensive tool that will do this. There should be many DIY videos on line.
2011 CTS Coupe AWD Performance
I used to pay shops for brakes but once my friend showed me how, it amazed me how much they charge for such a simple job. Depending on your mileage your rotors may be ok. I have always used Wagner Thermoquiet pads on my cars.
08 CTS blk/blk
Brakes and stuff
Hey all you happy dedicated CTS drivers!
I got some great prices on Amazon for brake pads and rotors.
I bought all new OEM pads and rotors (all 4 wheels) shipped $322.00
Plus! with some digging, bought 3 quarts of OEM gear oil (additive not needed).
Bottom Line! I had all new brakes and rotors done, gear oil front and rear DONE ! I'm a happy boy
I waited a very long time to change my gear oil (200,220) but surprisingly it was not that bad...but not recommended. It had some metal on the magnets but not scary. The oil was dark but again not scary.
Happy Motoring,
Joe
2008 CTS Base Manual Tran
Re: Brakes and stuff
Sounds like a great price...What is the brake/rotor kit part number(s) or just a link to the AMAZON page?
Thanks!
2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
Thanks!
Not that easy. Look under your spare cover to see if you have je5 or j55 brakes. Then go to acdelco website and their catalog and pull part numbers. Then search on amazon. 322 is awesome. I think I was 335 last year doing the same thing.
2010 CTS Sportwagon
Brake job question
I'm not finding a lot of information on this. I know it should be easy but I'm at a loss. I'm replacing the pads and rotors on my cts4 and I can't figure out how to lock the front wheels to remove the screw holding the rotor on. I'm sure I'm missing something simple. Thanks for the help.
2011 CTS-4, Sedan,Tuscan Bronze
Re: Brake job question
Two things come to mind. Loosen the screw with the pads still on and have someone depress the brake pedal or use and impact gun with the proper bit.
Loosening/tightening that screw should not be able to turn the entire assembly. It be must be seized on there pretty good.
Take a crow bar or pipe or anything long and slide it through 2 lugs with the bottom of the pole or whatever towards the rear of the car against the ground. That should lock it up enough to remove the torx screw.
2010 CTS Sportwagon
I tried that and started to strip the torx screw. I put some PB blaster on it and waited an hour and still no luck.
1 - 20 of 27 Posts
