I just found out that the Traction Control light and the ABS lights are stuck on because the right rear wheel speed sensor is bad and the electronic brake traction control module may also be faulty or the wiring to the module is bad. Whether it's the wiring or the module, I do not know. I just know that either is sending a message to the pcm.
Anyway, I called the guy I got the rear end from and he has agreed to give me a free speed sensor, since it's his rear end that's causing the problems. But should I take the used one or search for a new one? Where is it located on the vehicle? Because I still have my old rear end. Maybe I can just use the sensor off my old one?? After I deal with these two issues, I'll then be able to reprogram the PCM for the different ratios.
Come to think of it, these two lights were not on until I changed the rear end. This leads me to conclude that there is nothing wrong with my EBTCM and that there is no need to scour the wiring for a fault; it's obvious the wiring from the new rear end is messed up. Is it possible to replace the wiring on this new rear end with the wires from my old one?
Please advise.
Please advise.
