Installed the Revshift mounts today with a friend of mine and a 12-pack of Bud Light. I had no idea that my stock mounts with the juicy filling were in such rough shape -- the passenger side mount decided to spew its contents when my friend was removing it, and the driver's side mount was well on its way to completely falling apart.
Install took about 4 1/2 hours with two people working on it. We just jacked the front of the car up, no lift, but a lift would definitely helped get some of the more stubborn bolts.
Some of my findings about the install:
- Make sure you have good lighting. The bolts are all visible, but hard to see if it's dark.
- Be sure to have long enough ratchet extensions. A few bolts are easiest to get to if you have a lonnng (1 or 1.5 foot) extensions.
- A universal joint ratchet coupler. A couple bolts I found to be awkward to get directly at, having a u-joint helps.
- Patience. Getting the bolts out isn't *too* hard, but getting the assembly out once the bolts are out is a pain in the butt.
- Getting the mounts OUT: Once all bolts were out, I wiggled it until I could remove the bottom bracket while it was still lodged in its area on the car. Then I removed the other bracket with the liquid mounts.
- Getting the mounts IN: I installed the mounts the opposite way -- I bolted the new mounts onto the upper brackets first, then got them into position on the car. Then I wiggled the lower bracket in and assembled it to the mount. This is more of a pain than bolting everything together outside the car, but it's easier to re-install. Then I finger-tightened down the upper bracket first, then the lower bracket, then lowered the engine back down before re-tightening everything.
Results?
The hard starts are gone, and the car is overall much more smooth. My mounts were so shot, that any kind of solid mount would be a big improvement, but so far, the Revshifts are fantastic.
