1 - 2 of 2 Posts
I found a friend who can do a vin swap for me(he thinks it will work also) to get the govenor to 150mph. I just need a vin # from a 2001 cadillac STS with the w-rated tires. If anyone has a 2001 sts that wouldnt mind sharing the vin number, it would be appreciated. I know its a long shot,but ive been checking ebay and used car lots for months now with no luck yet.
Frank
What are you trying to do? The VIN doesn't reflect the tire type you know.
The setting is just in the PCM flash. If you had ordered the other tires, it wouldn't have affected your VIN, GM would've just selected a different flash for the PCM and THAT would change the speed limiter. You CAN get a custom PCM or get yours re-flashed to get rid of the speed limit.
1 - 2 of 2 Posts
