1 - 2 of 2 Posts
I need a little help here, I have an 85 Fleetwood 4.1 Brougham 4.1 I need to get to the warning lights above the speedometer cluster, how do I get access to the bulbs to change one. hope there is an easy way to do this. If anyone could offer advice I would appreciate it.
Paul
70 Fleetwood, 87 and 90 Brougham, 94 Fleetwood
The top panel of the dash can be removed. This will give you easy access to the warning lamp cluster.
There is a screw on either side of the dash, 4 in the defroster vent and a few that are accessed from underneath. They can be found at the top of the instrument cluster, through the top of the glove box abd through the centre AC vents. You will have to remaove these vents to access the screws.
Mike
1 - 2 of 2 Posts
