I thought I posted about this a while back. I've had my replacement lenses for months and will probably get around to installing them this summer.
That has a rubber seal on it. You have to heat it up to like 250F in your oven until it becomes pliable and pulls apart. Then once you have them apart you need to remove all of the sealant off the mating surfaces and when you put it back together you need new sealant to put inbetween them. I do not believe they are also screwed together but you can likely remove the screws before heating it up. New lenses can be found on Ebay.
It's butyl rubber and I'd limit the heat to 225F for about 15 min. The screws come out without a problem. On this repair I recommend the original butyl rubber sealant as opposed to the silicone free caulk sealant. The butyl is much tougher to remove without research but It's proper and better. The silicone free caulk gives off a good bit of moisture as it cures and you can end up with condensation inside the headlight in the process, I did.
It's also important not to make the same mistake the factory appears to have and that's drive the screws in place over the butyl rubber instead of clearanceing with a pilot hole, forcing it into the threaded hole, stressing and cracking it open. You will probably find on disassembly that the bosses for the screws are cracked, or fractured resulting in the loose seal that leads to water entry.
Great find! The listing seems to indicate compatibility with both HID and Halogen. That would be a game changer, I was finding it difficult to blow $1,800 on a pair of HID headlights (before they're discontinued) to have for the inevitable yellowed lens problem.
If you're going to remove the lenses it would be a good idea to perform upgrades, or preventative measures, like going to a brighter light bar lead (done) and perhaps replacing the yellow marker led (I believe Long had one go out) although I'm not sure about the led type. There is also a clear lens upgrade also in place of the frosted appearing OE lenses.
