1 - 9 of 9 Posts
Howdy:
I am the proud new owner of a 04 Cadillac SRX. I love everything EXCEPT the OEM NAV system. I have a Kenwood DNX7100 in one of my other vehicles, and I would like to put on in my SRX as well.
Has anyone replaced the OEM unit with an aftermarket one? If so, where did you find the dash mounting kit for the new unit? I have found a kit for a non-NAV w/Bose system, but not for the NAV dash. Are the climate controls under the NAV system the same as the non-NAV cars?
A rep that I talked to at Crutchfield said that the dashes with the NAV in them have a slightly different curve than the dashes without the NAV.
Any help/advice/links would be appreciated!
Thanks.
2005 SRX
The HVAC stuff is the same. You will lose the DIC information the factory NAV unit currently displays. You can maintain the chimes. After that, Onstar and XM will depend on what you new head unit supports.
Let me know if you decide to do this. I want to install OEM Nav!
The DIC?
My main concern is are the dimensions of the NAV unit and the stock radio unit the same? (same curve on the front, etc) From photos, they look pretty similar.
As for wanting add OEM, I will have one for sale soon :)
2004 SRX V8 AWD, 2008 STS V8 RWD
If I would be doing this I'd double check that steering wheel buttons are going to work with the new unit correctly. Definitely wouldn't wanna lose those.
2005 SRX
Driver Information Center. You won't have any of your mileage, range, outside temp, oil/trans fluid life information with an after market headunit.
IN the CTS forum there is a document on how to gut a non-Nav head unit to keep the DIC display and install an after market head unit.
Terry
PAC makes a unit that will keep the steering wheel controls (used on in my Jeep Grand Cherokee, and it works like a charm). They also make a module that lets me keep the OnStar integration as well as the door chimes.
I would head to your nearest Cadillac dealer and check out the non-nav. You should be able to tell by seeing it in person.
Discussion Starter #9
Nearest dealer is over 2 hours away.
So, can someone with a 04-06 with nav and some with the same years without nav please do a rough measure of the dimensions of the entire head unit and post?
Thanks.
1 - 9 of 9 Posts
