Thanks! The manual could sure use some pictures to help with bulb replacement, but it is definitely doable.RobertCTS said:You may be able to access this by turning the wheel I'm not sure. But my way gives you lotsa room to work.
do you replace the fog lamps with regular high beam bulbsRobertCTS said:Piece of cake. You need to jack the side of the car up. Remove the wheel. Remove the front wheel well panel. This exposes the bulbs. You may wanna think about replacing your Fog bulbs with the high beam headlight bulbs. I did that and was pleased. Here a pic of the inside behind that wheel well panel.
Yes.CADIMAC52 said:do you replace the fog lamps with regular high beam bulbs![]()
Replacing high-beam bulbs into the fog-lights sounds great, but am I going to be blinding on-coming traffic (like the HIDs seem to be doing based on other threads) and getting high-beamed in return?RobertCTS said:Yes.It works.
The reflector in the Fog directs the light downward. The highbeam bulb will project the light no farther. In over a year noone has flashed lights at me. It's an easy job.Anyadike said:Replacing high-beam bulbs into the fog-lights sounds great, but am I going to be blinding on-coming traffic (like the HIDs seem to be doing based on other threads) and getting high-beamed in return?
Also, I had the dealer replace one of my fog-lights and it's much brigther than the older one on the other side - I don't think it's from dirt inside, so I wonder if there are different intensity bulbs the dealer would be installing? I'm too lazy to buy 2 bulbs and replace them both with the same, but just curious if there was a way to maybe just change the older dimmer one (not referring to myself) to make it more equal...
Well, I've figured out why one fog-light is brighter than the other - the lights are not aligned vertically! I didn't know that fog-lights need to be aligned like headlights - how do I do this? I can't find instruction for this anywhere...Anyadike said:Also, I had the dealer replace one of my fog-lights and it's much brigther than the older one on the other side - I don't think it's from dirt inside, so I wonder if there are different intensity bulbs the dealer would be installing? I'm too lazy to buy 2 bulbs and replace them both with the same, but just curious if there was a way to maybe just change the older dimmer one (not referring to myself) to make it more equal...
you can get to the fogs without taking the bumper off, not the headlightsmikesharon said:I was going to buy some silverstar but it looked like I needed to take out the bumber to get at the lights according to the faq. Are you saying i can just jack up the car and turn my wheel and i can do a quick change?
