Is it as simple as removing the protective shield underneath the front end & popping a new bulb in, or is it a solid-state lamp that needs to be totally replaced?
There are around 13 plastic retainers holding the lower shield in. They pop right out. The bulb is replaceable, just make sure you don't touch the glass part with your fingers. The bulb will burn out sooner if you do.
