Hi all,
So I've come to the conclusion that I will be replacing the bose speakers in my CTS-V Coupe, and adding a sub and amp. I had a few quick questions however.
Reading this forum: Finished audio install- Speaker swap/New Sub - pics
This guy and a few others found great success swapping the 3x Bose 3.25" speakers in the dash and 2x speakers package tray with 3.5" Boston Acoustics S35 speakers. He has a sedan, so it looks like his rear 3.25" speakers are the coupes back side side panels, and the 5.25 door speakers he had are actually in our rear package tray.
So I plan on replacing those 5x 3.25" with the S35... but they are no longer available. Luckily, we have the stats of:
Sensitivity: 92 dB at 1 watt
Frequency Response: 100 - 20k Hz
RMS: 2-30w
Peak: 60w
Impedance (Ohms) 4
Top-mount Depth 1 11/16"
Bottom-mount Depth 2 "
I think I found something even better. The Infinity Reference X REF-3002cfx. The stats are as follows:
Sensitivity 91 dB at 2.83 volts
Frequency Response 85 - 21k Hz
RMS Power Range 5-25
Peak Power Handling 75
Impedance (Ohms) 3
Top-mount Depth (Inches) 1 7/16
These should sound even BETTER due to being 3 ohm speakers. The factory 3.25 bose is 3.2 ohms.. so this should be a much higher quality dead on match. Correct?
Or the Polk Audio db351;
Sensitivity 91 dB at 1 watt
Frequency Response 90 - 22k Hz
RMS Power Range 4-35w
Peak Power Handling 105w
Impedance (Ohms) 4
Top-mount Depth 1 9/16
Any suggestions for the 5.25"s and/or 8" Front door woofers? If I have to, I will just buy new OEM as my drivers door speaker sounds pretty rough. And I will be using Fatmat/dynamat extreme when I do all this.
RMS: 2-30w
Peak: 60w
Impedance (Ohms) 4
Impedance (Ohms) 3
Impedance (Ohms) 4
