1 - 20 of 43 Posts
I Replaced my front windshield today with what the glass guy said was a better quality glass than the oem ones. He went on to say he's done lots of V's and XLR-V's and says that GM messed up when they installed these as they "sit at a poor angle and that they induce rotting around the rubber edges far quicker than any others out there"...Seems like the glass was cut at a slightly different degree on this one at that's what the X-vette racer slash window guy said...
Mine was just pitted and a little cracked so I called them.:eek:
No picture yet as I'm waiting for new tint but this glass looks like it is flatter and a bit more aggressive looking with more smoked tint on the bottom section.
Ours seem to sit more upright but there's definately a sleeker look....
Chef
edit - hearing some grinding when shifting into gears? tranny? diff?....oooh no...damn you mod dementors....damn you!
See you in the funny papers
04 CTS-V, 05 STS, 07 SRX- All sold :(
I have the utmost respect for you Chef, but.......what!? :confused:
The angle that the windshield sits at is determined by the angle of the A-pillars, so unless your windshield guy cut the frame and welded some new pillars in there for you, the glass will be sitting exactly where it always has.
Sedan de Ville, CTS
Hope he included a few gas saving devices for $19.95, new secret technology that will improve gas mileage UP TO 99%.
2005 Cadillac CTS-V
:woohoo::woohoo::woohoo:
I'm going to weld my doors and add a window net.
WHAT?
I'm gonna need to see a horespower rating on that before I do it.
Discussion Starter #9
The way the shield is seated coupled with degrees of glass being shaved will determine the sphere of the glass..or the bow of the glass. Perhaps it's optical - yes it sits on the same pillars (filled with rubber cocking) but when the old rubber is taken out it's set with new layers of cocking which we know- Some add more than others and some add less in terms of setting on the pillars. You're looking at the pillars not the flex of the window itself....
:alchi:eek:h yeah...need more beer.
Gained 5 more rwhp...*grin*
2017 Camaro ZL1; 2011 CTS-V sedan; 2004 Lightning
Discussion Starter #19
TDS Teak Cocking is a one-part, paste-like oxime cure system which when exposed to moisture in the air reacts to form a tough, flexible solid rubber compound. TDS Teak Cocking is a thixotropic material that does not sag during cure, and, when cured, has excellent temperature stability and chemical resistance. Because the sealant is neutral cure, it is non-corrosive to all substrates.
For "F"
TDS Teak Cocking is available in black or white.
2005 CTS-V Redline
TDS Teak Cocking is a one-part, paste-like oxime cure system which when exposed to moisture in the air reacts to form a tough, flexible solid rubber compound. TDS Teak Cocking is a thixotropic material that does not sag during cure, and, when cured, has excellent temperature stability and chemical resistance sometimes creating extra sleekness . Because the sealant is neutral cure, it is non-corrosive to all substrates.
For "F"
Whichever color you get, I wonder if it lighter weight.... to make your HP to lb ratio better.
1 - 20 of 43 Posts
