2013 XTS Luxury 3.6 : replaced with LED and worked fine then replaced with a custom welcome light, flickered and then turned off. Can you help me? I created a post but seen this one and trying to get help or fuse locationwould help to know year/model/trim/engine. also whether you replaced with OEM or LED.
Since it worked with the first LED but not with the welcome light, the welcome light is most likely not the correct bulb for the car or it is faulty. Take it out and put the LED back in to see if it works.replaced with a custom welcome light
I tried to put back the original LED light; but completely stopped working. If you google pop trunk you’ll see cars with trunks that life with a switch. Like a show car.Since it worked with the first LED but not with the welcome light, the welcome light is most likely not the correct bulb for the car or it is faulty. Take it out and put the LED back in to see if it works.
What do you mean by "pop trunk"?
The XTS trunk from the factory slowly opens once it is released. I guess you are talking of closing it like what the CT6 does.I tried to put back the original LED light; but completely stopped working. If you google pop trunk you’ll see cars with trunks that life with a switch. Like a show car.
Not at all;The XTS trunk from the factory slowly opens once it is released. I guess you are talking of closing it like what the CT6 does.
Is putting a neon sign on the inside of the trunk lid what you mean by a welcome light? If yes, I think that would require more power than a regular trunk light which in turn would require a special set up. Maybe someone who knows about this will drop by.
As to fuses, a list of them can be found in your manual. Good luck with your project.
Did you not say that you hooked up the welcome light, it flickered and then stopped working, then you tried the led bulb and it did not work (but before it did). So how can you say "not at all", referencing I guess my statement that the neon light may have required too much power?Not at all;
Inside of trunk there is a cargo light that comes on, once I open the trunk. This light isn’t coming on nor working any longer. Manual has nothing on where I can find this fuse that controls the light.
