2008 Escalde ESV
I was wondering if the bezel around the Heat switches and analog clock and 6 cd changer pulls off so that I can replace the switch? Or do I need to remove the center console to get to any hidden screws?
Don't want to break the bezel by trying to pull it off if it isn't supposed to come off that way.
04 ESV
Topic says replace heated seat switches... Anyway, yes that trim piece comes off with some gentle, yet firm prying.
03 cadillac escalade
To replace the switches you will need to do
1 put the truck in 1st and tilt the steering wheel in its lowest position(set the park brake)
2 starting at the right lower corner pull gently on the dash bezel and work around till it's free(gently around the cluster as you can break the bezel if your rough with it)
3 gently pull the bezel around the cd changer that also holds the switches and clock
The switches will be held in with a few screws
Reinstalling is reverse of removal
