Same message.I'm holding off changing that battery until I figure this out.How about the other RKE?
I tested the battery with my multimeter.They're good.you likely got some bum batteries
How is that possible?The RKE without the new battery is in the house. If you don't know an answer it's ok to say I don't know or not give a guess at all.No offense intended.Probably best to start with fresh batteries in both RKE's. If you have one that is low, you will likely get that message.
What does "Red" mean. Most meters with colored scales show green when good, red when less than adequate.I tested the battery with my multimeter.They're good.
That is a 3 volt battery. If it read .3 (3/10) volts as you stated, it is nearly dead. And as @Tripwire said, batteries must be tested under load. Even if it read 3 volts open circuit, voltage may drop when current flows.The battery tested GOOD.3 volts
Agreed...I changed the batteries in all FOBs for my three vehicles just a week ago. Immediately noticed an improvement in operating range.I consider keyfob batteries like smoke alarm batteries. If I'm changing one, I change them all, as the others won't be far behind in failing.
