I have one of those sticky parking passes on the corner of my windsheild, I want to remove it, whats the best way anyone knows to remove it easily and without any scratching?? Thanks in advance.
Yes, the best way to clean that stuff off of any glass is a sharp new single edge utility razor blade.SdMarineGuy said:I would use a sharp blade. Its pretty hard to scratch your winshield even when professionals remove tint they use a sharp blade. That is what I used to remove that gay antenna that was on my rear winshield when I bought the car.
Heating is not necesarry. The blade should work very nicely unless the sticker is exceptionally thick. Keep it at a good angle close to the glass and shave that baby right off.Caddy Man said:should i heat it first with a blow dryer?? or just go straight to removing with a razor blade?
Oh yeah, WD-40 is pretty effective in cleaning off adheasive. I've used it for that many times. The solvent in it workd very well, just try not to let it sit on your paint too long.MikeB066 said:I have not tried this so I cannot comment on whether it is really effective or not, but for removing tollway tags the county hands you a kit that includes a blade, some WD-40, and glass cleaner. They claim that the WD-40 attacks the adhesive making it easier to remove the EZ Pass tags, then you are supposed to scrape them off with the blade and clean the area with window cleaner. Again, I have not tried it so I cannot say definitively that it works.
When it comes to removing adhesive residue, lighter fluid, Goo-Gone, or other solvents work fine. I doubt they are good for safety glass though which should be an area of concern.
