CTS
Does anybody know how to remove the Overheard Console/Maplight pod in an '02 SLS? There are no obvious screws, fasteners, or clips. This is the small pod with NO sunglass holder. Just 2 Maplights and the Homelink buttons.
Thanks for the help
Kevin
2014 XTS V-Sport Platinum
Just pull down at each corner. There are clips holding it up. They are hard to get to come loose the first couple of times you take it down. There is a ribbon cable attached to it, so be careful once the clips start coming loose.
2001 ETC Sequoia
From your '02 FSM:
  1. Important
    Do not let the overhead console hang from the flat wire harness.
  2. Carefully pull down on the overhead console to release the four retainer clips.
  3. Disconnect the flat wire electrical connector.
  4. Disconnect the cell phone microphone connector (if equipped).
  5. Remove the overhead console.
Regards,
Warren
