Yea, nobody said it’s hard to find the proper tape. You can pick it up at your local Orrellys, it sticks more than fine..I had amazing luck with the 3m extreme double sided mount tape.
You don't need to make surgical cuts. Clean, wipe with 99% isopropyl alcohol, quick scuff with 80g sand paper or a red scotch brite and rewipe with alcohol and stick away. For the car side, make sure the wax is removed, alcohol wipe and stick it.
Sticks well and all materials are available at Ace hardware, Abu Dhabi. If we can get them here, I'm willing to bet you can stateside also.
If you would like a demonstration of the tape, the bare minimum of how to apply it and seeing it in action, click here.
-Byron
As far as that video, I can’t believe I actually sat through the entire thing.. I want 15min. of my life back. Lol
All jokes aside, what he did there is what’s known as a “hack job”. I’m a professional detailer and there’s no way that sort of technique & results would fly. Notice towards the end he said he’d have to take a razor blade to get the rest of it all off. Would you take a razor blade to perfect paint on a perfect car? Not a chance.
As far as not needing to make surgical cuts? Ok, here’s a fairly easy 1, right?
If this isn’t surgical, then maybe your expectations aren’t high enough?
Ok Mr. Exacto Knife, lets see how perfect you can get it.
Because when it comes to emblems, especially script...
It better be Perfect. Surgical. OEM
I’ve debadged & re badged plenty of emblems on plenty of cars, and I don’t do hack jobs. I’m not saying you do, but there’s the right way, and the hard way.
If given the choice, do yourself a favor and buy the emblems that come ready to use. Not only will they look better and in most cases be brand new, but the tape job will be perfect.
