C
Guest
Hi there,
can anyone help or tell me how to remove the dool panel? My rear passer window just off down and won't come back up i can hear the motor running. Anyway i just need some advise on how to remove the door panel. Thanks in advanced. My car is CTS 03.
> BMUU
> BMUU
here it is, http://www.cadillacfaq.com/faq/answers/doorpanel.html
INSTRUCTIONS FOR REMOVING DOOR PANELS ON CTS & CTS-V said:
How do I remove the Door panels
All Doors: On the bottom edge of the plastic door handle cover are two small cutouts. Insert a flat tool into that cutout about 1/2 - 3/4 inch and push up slightly to release the inside catch on the cover from the projection that holds it. It is best to do both at once to minimize stress on the door handle. Push up and out to remove the door handle cover while holding the door handle in the open position
Next, just behind the door pull handle, there is an oval piece that you pry out, and behind it are two screws. Remove these screws. Next, starting at the bottom, pry the door panel up and it will begin to pop and then work it around until you have the panel completely pulled away from the door. Now push up and out to get it finally off the door.
The front speaker is affixed to a bracket and then to the door. In the non-bose, it's a 5.25" (5 1/4") speaker, in the bose is (reportedly) a 6.75" (6 3/4") speaker. But keep in mind that it is 2 ohm (so a 4ohm speaker will produce less volume), and in both applications it's equalized (crossed) to produce below 6000hz, so you will not get very good highs from the speaker.
The rear is removed the same, however, the speaker is screwed to the door panel, not the door. It is a 4 ohm speaker and full range.
C
Guest
Thanks guys i will try this tomorrow morning.
