TLeTourneau said:
Also, you'll may end up carrying 2 fobs if you car has memory seats. The aftermarket remote start systems can not replace the factory keyless entry fobs if you have the memory option. At least that's what I was told when I looked into remote start on my 2003. If anyone has any other info please let me know
Tom
Actually they have interfaces that take care of that now. You can use the fob for the remote starter to do all of things your #1 factory fob does (plus a lot more). I just bought a 'databus/bypass module' to work in conjunction with a Code remote starter. I haven't installed it yet, but here's what it claims it does:
- bypasses the PK3 system for remote starting purposes (no key required; learns the transponder password)
- controls doorlocks maintaining the one-push driver, two-push all locks functionality
- controls OEM alarm with the door lock/unlock commands
- trunk release
- activates rear window defroster
- recalls all memory settings for Driver #1
- provides parking light confirmation of remote start or alarm commands
- activates heated seats
- activates heated mirrors
- automatically shuts down RAP at the end of a remote start cycle
- provides door trigger out for aftermarket alarm systems
It's a Crimestopper GM SL. Go to
www.crimestopper.com and click on the TechWeb link, then click on Databus to select your year, make and model. It will give you a list of the compatible modules. The GM SL has the most features.
It looks pretty straightforward to install. It communicates through the vehicle's databus by tapping into the OBDII connector feed. The only 'hard wiring' is to the databus and for the starting functions (ignition and PK3 bypass).
It was only $50, which is cheap when you consider how much wiring and time it saves you.
Before I became aware of the GM SL I had originally bought Crimestopper's GMDL2, which is a pared down version of the GM SL. It doesn't have the PK3 bypass built in, and doesn't do the heated seats/mirrors/defog. It does everything else though (memory for Driver #1, trunk release, door locks, etc.). I'm going to throw it on eBay along with the separate PK3 bypass module that I was going to use. I wish I had seen the GM SL first!
Jim
