1995 cadillac deville
Hello, to all members pardon my ignorance but i need your help i just changed the remote control battery of my 95 caddy and would not open the door. When you pressed arrow down it turn on the inside lights but when you pressed the arrow up it would not open the door also whe you pressed the trunk it opened. Would this mean i need a remote replacement or it can be repair? your help is much appreciated. Thank you
Thanks for your reply no this is the first time it happened. Can this one be repair or need to replace?
It would need to be replaced. But before you do that, clean the button contacts on the board and the underside of the buttons.
thanks for your reply moist cabbage but what type of cleaning solution do i have to use ? Can i clean with alcohol or what ? thanks again
Yeah alchohol or glass cleaner.. Soap and water is fine for the buttons.
