08 STS V, had 06 V6 STS
Hey members, I took my "new to me" 08 V in for the passenger side mirror to be fixted (a part of the due bill at purchase) because of a bad shake at freeway speeds. I also asked them to inspect the rearend because of signs of leaking...
The mirror is being replaced, I'm hoping the paint will match propperly... and the service department told me that the rearend is in fact leaking and the vent tube is being relocated. Has anyone had this come up? I only said something about it leaking because I've read that this is common and I wanted it to be addressed while still under factory warranty. I haven't heard of the vent tube being part of the solution.
Any thoughts?
2006 STS-V and 2007 STS-V The Murdalac
It's the pinion seal that is the problem. I've had my diff out and don't remember a vent tube.
I should be getting her back on Saturday, I will get underneath and see what they did and update.
Update:
Got a call Friday afternoon that my mirror isn't back from paint so the car won't be ready until Monday. I called today just to find out that the mirror is being installed and they are going to be addressing the rear end today. "should be" ready tomorrow.
Katie, I'm not at the upset point yet, but Rancho Motor Group in Victorville CA is where my car is. I will let you know if there are any concerns that they will not address. Thank you,
Update:
Picked up my girl today and here's what I found...
Relocate rear diff vent: F9706 install rear differential hose and vent 2682WG294
1 19132947 Vent
2 25518880 Nut
2 12337820 Strap
1 88900401 Lubricant
1 9439238 F-Hose
FC: 6061
Part #19132947
Bulletin # 07-04-20-001A
Once I got her home, I jacked up the rear of the car and took a look. There was in fact oil that was coming from the top of the diff and had leaked down to the undercarriage of the car. I can see the hose that was placed over the top of the rear end. I cleaned up any signs of leaking and will take a look again in a few days.
2007 STS-V mine and 2010 CTS wife's
I've never seen a differential leak oil from the vent tube before... You might want to ck the diff oil level... It should be even with the side fill plug. Does your car have a diff oil cooler installed?
