1 - 13 of 13 Posts
1999 STS - diamond white
I'm sitting at a shop getting my car serviced and was thinking; My Driver 1 fob is beat, the buttons are unreadable, and it's corroded inside. Probably from my sweaty pocket. Is there a good source for new fobs? Lot's of places sell them. I got 2 new ones for my Ford Focus on Amazon and followed the instructions for programming them. Is it that simple on the STS? Anyone had a good experience down this road?
No way to program the fobs yourself, a TECH II scan tool is required. Any GM dealer can do it.
Used fobs are plentiful and inexpensive. #1 and #2 fobs are identical other than the rear plastic cover. I believe basscatt knows the part numbers that will work with your car.
All fobs you plan to use must be present when the new fob is programmed.
2007 DTS LuxII, 1969 El Camino SS396, 2008 GMC 2500HD Crew Cab 4x4,
I have bought fobs and key blanks for my SLS from Amazon relatively cheap.
Discussion Starter · #4 ·
Thanks MC. I see used ones on Amazon for $25. I guess I'm at the mercy of the dealer or some other qualified shop to get it programmed. That can't cost more than $50 can it?
I paid just under 20 bucks for a new fob and 14 for the key blank.
ebay
easy with a TECH2 scanner -
impossible without it -
Discussion Starter · #7 ·
Thanks guys. I'm seeing 3rd party fobs for much less than even used GM fobs. Not sure if the quality and range is comparable.
I wouldn't recommend the aftermarket ones at all.
Used OEM are cheap enough and very reliable.
That's what I'm thinking.
if the fob still works - you can "rebuild" it -
brand new case -
available in several colors -
brand new keypad -
and just re-use your original board -
so - no reprogramming requited -
less than $5 - including shipping -
http://www.ebay.com/itm/Replacement...its=Model:Seville&hash=item486760a90e&vxp=mtr
you must be very careful buying remotes -
the listings are often wrong with the application -
I know #25695966 and #25695967 will work with the 2001 and newer Seville -
but I don't think they work with the older models -
just check the numbers on your existing remotes -
and order the same -
regardless of the "DRIVER" number on the fob -
you can have two of the same number -
the first unit matched to the car will be DRIVER #1 -
the second unit matched to the car becomes DRIVER #2 -
Discussion Starter · #11 ·
That's a thought. i need to see how corroded the board is. The casing is broken all the way around it.
1999 Deville Base; 2001 Seville SLS
I have a '99 which came with one fob, and I bought another one from ebay, naturally with no way to program it myself. I asked our local Caddy dealer about getting it programmed, they told me it would be $60 - one hour's labor; I decided to wait. That was a few years back. Fast forward a couple of years, and I braved my way back to the dealer to learn that it was now gonna be $75. I declined again.
But I did find a locksmith that does auto key work for the local auctions and rental companies, and they have an "Advanced Diagnostic" box that can pretty much do anything a Tech II can do, and they let me use my car and fobs for training their new guy. Now I have 2 fobs programmed.
'99 Seville STS; '96/7 ETC
Now I realise that (1) the situation is different here, because by the time a car's that old, the only realistic solution is to have an auto security company fit an after-market system & (2) this will be considered rather reactionary/leftfield, but - why bother?
My experience has been that fob batteries last 12/15 years, the replacements last a couple of months (assuming you've managed to fit them in the 30 seconds available before it loses its memory), so when the fob fails now, I just except that that's not a bad life for what is, in truth, a glorified novelty & use the key - simple! Remember, even the user manual warns that the fob is no substitute for a key. (if you've read my earlier thread, you'll realise there is a certain irony in that)
1 - 13 of 13 Posts
