2000 STS
I have a 200 STS and everything was working fine until I removed my throttle solenoid to clean it. After reinstalling the throttle solenoid, I noticed that the engine idle speed seems to float between normal and as high as1500rpms. I tried resetting the ecu by disconnecting the battery but no luck. Any help finding a solution would be most appreciated. Thank you.
2000 STS
Thanks for the reply. Yes, I mean to say IAC valve (wasnt sure of the correct description untill now) . I will try cleaning the Throttle body and see if that works. Thank you.
