I finally got motivated to fix my left-rear window.
After eight years of not using the window, because I knew at least one of the regulator slide clips was broken, I hit the rear window switch by mistake the other day. Now I can't get the window rigged to stay up at all. After a day of window plastic, 100-mile-an-hour tape, and my wife using the term "Hoopty" more than once, I am compelled to fix the darn thing.
I've got the door panel off. I drilled out the rivet on the right end of the top regulator slide to remove the old, broken, plastic clips. Both clips were broken in half. Everything else seems to work fine, motor, regulator, etc.
My quest is where can I find the plastic clips. It was late today, so I only had access to the local Advanced Auto. I checked the "DoorMan" parts catalog, but the only window part they list is the motor assembly.
Any ideas? Tomorrow I go to the local dealer to see what they may have.
I'm taking some pictures of the panel removal process if anyone is interested.
thanks,
Stan
thanks,
Stan
