Hello all. This is my first post so I hope someone can help. I bought an 05 Deville and it's had some issues already. The latest is the the passenger rear window does not go down. It did when I bought the car. Now it just clicks. I hear it click when
I push either the driver controlled rear switch up or down or the one on the back door. Not sure if it's physical or electrical. Any ideas?
2010 DTS
Chances are it's a bad regulator. Pretty common in the 2000-2005 Devilles and known as the pop n drop syndrome. Pull the door panel and if that's the case, check the Tech Tips section for a cheap and permanent repair.
2003 Deville Base
very common, and not as hard to DIY as you might think. Plenty of tech tips on this forum to help you thru it. Parts are plentiful
