1 - 17 of 17 Posts
I have a 2007 CTS with a regular rear veiw mirror. I was wondering if I change it out with a mirror that had the built in compass option. Can I just swap them out or do other things need to be done.
Thanks for the help.
Black the Darkside
You see them from time to time on eBay. The wiring harness should include the wires you need. I think the mirror gives you auto dimming for bright lights behind you. OnStar should be there on the mirror as well.:thumbsup:
And :welcome5: to the forum!
I appreciate the replies. I had contacted the dealer and they could not give me a straight answer. They went as far as to say that the computer might have to be reprogrammed. I will give it a shot, thanks
Black the Darkside
Forget the dealer. He's blowing smoke. You will have to orient the compass when you get it. Instructions should be in the manual. Easy DIY:thumbsup:
CTS
Yeah, the dealer typically won't give a straight answer to a question like that - or may not know the answer. Then again, they may be thinking that you might order a new unt from them - big bucks.
You should be able to pick one up for $50 or less - think I paid $35. The bus will pick up the additional input from compass without skipping a beat. It's a real no-brainer.
And...as RT said, welcome to the forum!:thumbsup:
Just my luck the only 2007 rear view mirror w/compass I have seen was just sold on e-bay. Can I use another model years (ie 2005) mirror? Thanks for any help you can give.
CTS
To my knowledge, they're all the same. The mirror I installed was from a '06 - my car is a '03. If your parts dept will talk to you, they should be able to verify.
Sedan de Ville, CTS
Pep Boys sell a compass (3" in diameter) for just a few bucks. With any luck, they might also have some fuzzy dice available.
CTS
I purchased a replacement mirror with a compass for my daughter's 2005 CTS. I believe starting with the 2005 model, there is a different display at the bottom of the mirror concerning the passenger air bag status. You would want this same display so look for that on the mirror. It was an easy change along with changing the visors to include Homelink.
Cadillac CTS - 2005
According to my 2005 Vehicle Build data sheet, option UAV - "DVD Navigation System incl: XM satellite radio - . . . (description of XM) . . . (deletes compass in mirror)". There must be some reason for deleting the compass.
lacks panache, bb, lacks panache...:bigroll:
now the fuzzy dice - that's another matter... lol
Marv--BB is an original 'tongue-in-cheek' poster. :lol: He's a champion of the sneaky :zing:.
Premium Member
The compass in the mirror is deleted because the NAV tells you which direction you're going. It's the same in my STS.
Discussion Starter · #17 ·
I was finally able to locate the right mirror on e-bay.. It took longer to clean the sellers ID number placed on it then it did to install it... Dealer price $350+. my cost $49.95. Thanks for everyones help.
1 - 17 of 17 Posts
