1 - 20 of 28 Posts
Banned
Does anyone have a GoPro (or equivalent) and the ability to point it at the rear tie rods to see if there's any flex in them during hard acceleration and cornering? If so, what are the chances that you might be able to put up a video?
2004 CTS-V Raven, StainlessWorks header back exhaust
I am trying to edit in a little brightness right now cuz there isn't enough light really. You want this thing uploaded to YouTube or emailed?
Word, youtube for all... Apparently when you don't plug in your laptop and the battery dies, you have to start the whole damn thing over... I'll try to have it up within the hour
EDIT: It's really weird watching the car from this angle. The video camera was stuck to the gas tank because the sticky mounts I have wouldn't stick well to the frame, and I didn't want to lose the camera half way down the road. I'm not sure what everyone is looking for but I am pretty aggressive around the corners and I did a 60-100mph ish pull to see what would happen. The video isn't long because I have a rather short commute. If you want a different angle or whatever let me know. I may try to duct tap a flashlight under there if I have to do it again for some better lighting.
Banned
Discussion Starter · #7 ·
Youtube, please. Feel free to make it all kinds of ugly--all I'd really like to be able to see is whether there's any flex in the tie rod. If it bows under compressive load, that's a great reason to upgrade to the BMR tie rods. There might also be a side-to-side motion due to the rubber bushings in the tie rod, but that's going to be difficult to detect. Even a small deflection can throw your camber angle off quite a bit, giving you uncontrolled launches or unpredictable cornering.
Ok here it is. I tried my best but I think I will try to redo it tomorrow on the way to work. I can't do it tonight on the way home because it's going to be dark at midnight lol. Also I don't know much about video editing so I may have just messed it up worse by trying to adjust the brightness... BUT I was able to flip it so you can look at it right side up when its on the car LOL thats how I roll, trying to make it easier on you guys haha
twin turbo rear mount V1 CTS-V built 383. 875/860RW pump/met
i cant tell if the toe arm is flexing but the sub frame sure is. do you have stock bushings on that thing
yea stock bushings... the angle is pretty poor, I'm gonna try it from the back looking forward tomorrow. There just isn't much good stuff to mount to on there.
The problem with the GoPro is that you can't see where its pointed and I dont have the rear LCD screen so I kinda had to guess what was getting recorded. You can see it kinda from where the camera is mounted but the lighting is horrible.
Banned
Discussion Starter · #11 ·
Thanks for trying, but you're trying to capture the thing pictured above. The second picture is a comparison of the stock part and the BMR part. Note how the OD of the tubing is doubled and the rubber bushings have been replaced with ball joints.
Yea sorry fuzzy... Its just hard to get light up there... I thought we could see it better with the angle I had but I guess not. I'll try again tomorrow on the way to work. I have a little led flashlight in the garage I'll duct tape up there. We shall see what's up then
Banned
Discussion Starter · #13 ·
I really appreciate the help. If it turns out that there's a lot of play in those tie rods, I'll put together a group buy on the BMR parts or bug Killernoodle again about making them.
Just a heads up, im about to make a set for my car and If they turn out good I could make a few more. It looks like theres only 150$ish in parts to make them
Banned
Discussion Starter · #15 ·
Adjustability is key. The BMR CTS-V set is a PITA to adjust. Look at some of their better parts for inspiration. Like this, but with ball joint ends:
they would be super easy to make. as long as you used a reverse thread rod end on one side you u can back off both jam nuts and twist the bar to adjust. im pretty sure thats how the bmr ones are made.
i plan on making mine out of some cromalloy i have laying around form our hydroplane
2006 CTS-V
Hydroplane?
Yeah I work on the GP-55 crew. She make about 1800hp on alcohol and 17 psi. I can make a thread about the boay if you guys want more info
2005 CTS-V Maggied
Yeah I work on the GP-55 crew. She make about 1800hp on alcohol and 17 psi. I can make a thread about the boat if you guys want more info
Very cool ! I go to the races all the time in Detroit and San Diego and have met Scott a few times all the way back from when he was driving Mr. Pringle!
Post up some pics of your new tie rods when you get them done! I'd be down for a set.
1 - 20 of 28 Posts
