STS
I have 2005 luxury performance RWD v8 STS (150k). The rear suspension gets bouncy on some roads. Normally I would replace the rear shocks but with the magnetic ride control could it be another issue.
Is there something else I should check out first before spending 900 on replacement shocks? The front seems to be very stable at this time. I have also adjusted the settings from sport to touring without a noticeable improvement.
2006 Cadillac STS V8 4.6L
I am just running into this issue with my 2006 Cadillac STS 4.6 V8. I am going to the air shocks at $68 a piece off of ebay. My mechanic has done this to another one already and he said the vehicle he put it on rides smoother than silk.
Yes. I am figuring since the vehicle has 115,000 miles on it I am not going to spend 1/6 of what I paid for the car on the rear suspension.
2008 CTS4 DI - EU version
I think someone here said that it's doable, but that they don't like/approve of it, heh. Would that cause some issues then? The ECU thinking it has MRC and freaking out or whatnot.
Edit: Oh, it was something a bit different...
While I'm not a fan of it you can always bypass failed MRC.
You can bypass MRC using the proper load resistor to prevent the car from being speed limited to 80 MPH.
You need to put a resistor in place for each shock you've swapped out ... IIRC you need a 3 OHM 50 watt resistor.
2006 STS4 V8 1SG & 2007 STS V8 1SE
You're giving up a premium feature to save less than a penny a mile.
