1 - 9 of 9 Posts
On my '02 lade the rear passage seatbelt is fully pull out and it wont retract back in. I tried pull hard on the seatbelt to get it retracted. Didn't help at all. Anyone have the same problem before? If so, help.
2012 Escalade, 2014 SRX
I have had problems on other cars, for me hard pulling fixed it, but if the spring (retractor) breaks then it's game over. :(
2003 Cadillac Escalade ESV
The Seatbelt warranty is 5yr 60,000 miles I believe. You might still be within that period I'm not sure.
I havent still replace the seatbelt retractor, can someone help me out on finding the part number? Thank you
the warranty is 4yr/50,000, the retracter inertia lock may be jammed with a little debris, and no, the dealer will not "fix" a safety belt, its a liability issue. if maybe there is debris and dirt in there , you can disconnect the belt at the mount end, blow some air in the retrater and tug, it, wiggle it, jiggle it bang on it, it will probably free up
Discussion Starter #9
I tried that, but unfortunately it did not work. I just want to get it replace, but the part number and it's not on the retractor.
1 - 9 of 9 Posts
