1 - 2 of 2 Posts
2000 Catera
Has anyone had the rear main seal replaced? I have a 2000 sport. Just curious what I need to get to it. Does it require pulling the engine? I Will be replacing oil pan seals, since that's where it looks like it's leaking and seems like and easy and cheap do-it-yourself job. Any input would be helpful, thanks!
You dont have to pull the engine but the transmission needs to be removed to replace the rear main seal.... Be sure that its not the valve cover gaskets leaking down to the ground, Leaky valve cover gaskets sometimes are confused with rear main seal leaks. :)
1 - 2 of 2 Posts
