2003 DTS 200k miles
My '03 DTS's load leveling raises for no reason. Sometimes it's fine and other times it will be up for no reason, even after its parked. When I go to drive it I never know if it will be up or down. There is a air ride sensor (RH REAR SENSOR,FWD,4.6L,ATOD,DTS) on ebay for $35.00 plus shipping. How do I test to see if it's the cause and if so would this be the part to replace? There's also a LR.
Before you replace it, inspect it. Make sure the linkage is connected.
2008 SRX
Not too likely to be the RH rear. You'll need an ohmeter to test the sensors. Check codes first. LR sensors are always the culprit with erratic level ride issues on your car.
2003 DTS 200k miles
No codes. What's the difference between the LH and the LR? Thank you for your help.
