1982 d'elegance
I need to replace my leaking rear level ride shocks on my 1982 sedan deville d'elegance. Can anyone who has recently replaced these shocks help me with my project. (brand and model # would be very helpful)
'81 FWB, '99 Century
If I remember correctly, you can just use any air ride shocks. I went to pep boys for mine years ago. Jack the rear of the car up and put it on jack stands at the frame. Unscrew the air lines. Jack the rear slightly to take pressure off. When you disconnect the shocks the rear will drop a few inches. Loosen the top two bolts first because they are the ones that will give you problems (if any). They're hard to get to and the shop manual says to bend a 1/2" wrench to reach the nut on top. Then unscrew the bottom bolt and yank the shock off the stud. Might have to pry or hammer it a little.
All aftermarket air shocks will work if ordered by proper application ( year and brand of car) plus you will also need to order the air line kit to properly reinstall the air lines. Cad air shocks had 2 fittings on the left rear shock and 1 fitting on the right rear. Aftermarket will only have 1 fitting on each requiring an air line splitter ( tee) to be installed. Thats what i did on my eldo.
