Premium Member
'79 coupe deville, '04 Deville DTS White Lightning
2009 Cts4 3.0. When coming to a stop, as the rear squats back down after lifting up from the stop, you hear a noise in the rear end. Not terribly loud but noticable. Like a metal "clack" noise. Not able to duplicate it using speed bumps. Only seems to happen on stops. Before I get out there and start investigating, anything to look out for? I've done extensive searches and found a couple of TSBs but none really describing what is taking place here. Thanks.
Premium Member
Thanks for the response. Just did a search and no go. I did find that the ignition recall is incomplete though. Any other suggestions?
Premium Member
This is actually one of the ones I saw when I did a search. I'll keep this in mind when I pull the wheels. Thanks.
