1 - 9 of 9 Posts
2012 Escalade EXT
This question is regarding my 2012 EXT…Has anyone replaced their rear differential cover with an aftermarket cover that contains both drain and fill plugs? The aftermarket diff cover needs to clear suspension parts without modification.
(I searched this forum and only found one post that was old, and the owner had to modify the cover)
Thanks in advance for your advice.
2009 AWD Escalade Ultra Luxury Raven Black
Good question. I'd like to know as well. I just bought a reusable diff cover gasket from Carquest. It's the same type of gasket as the transmission pan. Cost is ridiculous, 35$.
2012 Escalade, 2014 SRX
2014 S550, 2018 XT5 Platinum, 2019 XT4 Sport :)
You want to remove it every time you do a fluid change ( should not be all that often ) to remove all the metal shavings on the magnet. Also if you see any big stuff, you have a chance to get the rear repaired before the bill gets bigger the longer you wait or don't catch the problem.
I guess if there is a cover with a drain plug with a magnet, then its a win - win !!! :yup:
We usually do not see any shavings after we clean them the first time on recurring changes, so much so that I only take the cover off mine every other time, with the suction machine it is a 10 minute change start to finish, but then again I am old and have a lot of time
Hcvone, I just purchased the following:
1. http://www.factoryauthorizedoutlet....r-compressor-w-wheels-1862?CA_6C15C=826902483
2. http://www.amazon.com/gp/product/B00IFD5UDQ/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
3. HVLP $30- Gravity fed Air Gun ( I fill it with Ice Car Wax ) 1 bottle lasts me almost a year, 2 cars every other week or so. This is one of he best investments I have made. After professional detail on the trucks once a year, I wash and wax with Ice. It is absolutely amaizing. It takes all of 10 min to spray the entire truck, rims glass and wipe down. It goes on so thin it is a great solution for in between details. Car Washes make $$$ 29- to $50- to spray wax.
4. Motive Power bleeder. Had this for years, works great.
I now do most of my own light maintenance, I actually enjoy it and know it gets done right.
A. Oil changes with Wix XP filters ( Same filter for SRX and Escalade )
B. Suction / Fill Power Steering every 2 years.
C. Suction / Fill / Bleed brakes every 2 years, takes 1/2 hr. per vehicle start to finish.
D. Drain Front / Rear Diff. every 3 years.
E. Transmission Filter every 3 Years. Suction / fill what came out of pan. With the above machine, I can see the exact amount I removed and refill the exact amount. Every year or 2.
F. Transfer case, drain fill every year or two. Very easy...
I also purchased 4 of those Black Ramps from Walmart / Autozone. I drive up on all four at the same time, wala my own personal level lift.
1 - 9 of 9 Posts
