1 - 8 of 8 Posts
1995 Deville Concours 4.6 - 170,000 miles
Hi, can anybody please tell me how many rear center hydraulic brake hoses are on a 95 Deville and specify also the location if would be an easy DIY?
I'm aware about the rear left and right ones and I have already changed myself the front ones. I hope rear ones all change same easy...
Thank you, much appreciated.
Discussion Starter #4 (Edited)
Thanks a lot. I can see the rear left and right ones( #50 and the other one which is detailed on the far left upper corner of the picture). The center one might be #49 and probably there are 2 of them like center left and right. Probably best I can do is to look for it when I'll change rear left and right hoses. I have already bought only one rear center hose was like $3 from rockauto, just wanted to be prepared and have it handy so in case I'll be able to find it and have a reach on it to replace this one too.
Meanwhile I'll need to get myself the special hose wrench...Would anybody remember what size this special wrench should be?
Thanks.
2010 DTS
Hose wrench?
If you are talking about a flare nut wrench, I'd just buy a set. When you need one, there is just no substitute.
Discussion Starter #6 (Edited)
Oh, thanks this are the ones sorry for my interpretation... SAE or metric?. 5/8 fits the nut on the hose but not sure if this is the same size with the one on the hard line that I'll actually disconnect from but a set will give some size coverage anyway. I see sets of 6, 9, or 12 SAE+metric. Probably a small set 6 pc sae+metric which runs like 20 bucks will cover me for now. Opinion?
Thank you Ranger.
2010 DTS
SAE or metric?
:noidea:
I have a 3 wrench set (one on each end making it six wrenches). It's SAE (purchased decades ago) and is all I have ever needed......................so far.
1 - 8 of 8 Posts
