02 EXT
I have an 02 EXT that I have owned since new. Odo sits at 115k. I had a Ground Effects lowering kit (3/2 I believe) installed when new, and put in Baer 14" front and rear rotors, along with 22s installed then as well. I tow a boat (6500 lbs) and a utility trailer, both on occasion during the summer. I have noticed that when doing brake maintenance (changing pads) the rear brakes are worn at twice the rate as the fronts. Does the brake system have a proportioning valve that might be the problem? Is it adjustable? I would think that if I'm not getting the proper pressure to the fronts that I'm not getting the stopping power that I should. I have read on a few other posts here of a similar complaint, but no suggestions as to why this might be happening. Any suggestions what to look for?
jgriff,
I have observed the same on my 2003, rear pads wear 2, 3 times faster than fronts. I have 125K miles and only on my second set of front pads which are still very good. My theory is that there is a proportioning valve/setup biased toward the rear. My guess is GM did this on a 3 ton "luxury" vehicle to prevent nose dive on braking. Nose dive on a truck this heavy would be very noticable and not a luxury trait - just guessing.
2002 Escalade
jgriff,
Agreed, I could see them doing that.
53 Eldo, 54 CDV, 74 FWB 96 FWB (sold),1998 STS(sold), 03 ESV
This is the case. GM designed the rear brakes on this vehicle to do much more work.
