Rear Amp Wiring Diagram
1 reading
21K views 4 replies 4 participants last post by  bozzchem
So I found the thread for a 2013 ATS for the sub DIY, but not of the connectors have wiring that matches what is in that post. Is there a specific wiring diagram for the ATS-Vs? Mine is a 2016 with the premium Bose system.
For now I've tapped off of the rear sub wires and use the speaker level input on my amp for half of one channel, but I think I want to add an active LOC and sum signals from the other rear speakers, I just don't know which wires are for what at the amp. Just tapping off the rear sub doesn't sound that great as compared to the same system when it was in my Corvette that was fed signal by an aftermarket headunit with RCAs. I suppose I could take the trunk liner out and trace the wires, but a wiring diagram would be nice.
#5 ·
I had a competition JBL system in my last car. It left little for trunk space but would make your eyebrows twitch.
What are you looking for? How much trunk space are you willing to sacrifice?
https://www.amazon.com/Rockford-Fos...AQ2W2Q/ref=sr_1_1?srs=2530319011&ie=UTF8&qid=1527801248&sr=8-1&keywords=p300-10
You can tap in to speaker level or go for line level. If you want to stick with line level to ensure better bass, go with the above.
The other options is to go all out and it will cost you.
