I like the idea. Especially after discovering (this AM) that the PCM runs hot enough to cause pain if you try to pull it right after a road run. If you really think about it, just how much air flows through the air box at, say, 35 mph? Not much, because the throttle butterfly is barely off-idle and engine vacuum is up around 20". There's 8 or 10" of PCM pigtail to fool with, so there must be a solution.........OR go into the top of the existing box, through the cover held on by the resonator bolt.........
