1 - 9 of 9 Posts
STS,
Re: 2011 STS Big Brake Option for the Rear Installation
Would like to install large rotor 320 mm and perhaps a caliper upgrade at the rear. The factory installed small rotor 298 mm, or smaller. The stopping power is very weak. Thoughts and suggestions? The current caliper is factory, which is similar to Duralast Bracketed PN: 18-B4875.
Thanks in advance.
2006 STS4 V8 1SG & 2007 STS V8 1SE
Rear brakes don't do much of the work, regardless. I'd recommend upgrading the fronts if you can't brake hard enough to engage the ABS. If you can feel the ABS working through your brake pedal, you need tires, not brakes.
But it's your car, have fun!
2010 STS4
I have a set of JE5 320mm Drilled/Slotted rear rotors and Akebono ceramic pads that are almost new. $75 + shipping. I also have the upgrade Drilled/Slotted JE5 front rotors, PBR calipers, Akebono ceramic pads for the front, also almost new. PM me to make a deal!
68 DVC, 96 FLTWD Brgm, 11 CTS Premium (two)
The rear brakes do maybe 15-25% of the work. Don't bother.
2007 CTS Sport 3.6
I have JE5 brackets for the front and rear if you're interested.
2006 Cadillac STS4 V6
I have JE5 OEM rotors. You can pick it up if you are somewhere in the 18031 area.
2007 CTS Sport 3.6
You dont have to change the caliper to get the bigger brakes, you only need the bracket and rotor thats it.
05 STS4
Wrong
JE5 does NOT share the caliper with JL9. They are in fact different.
2007 STS 4
Hmmm I know this is an old post. Do you still have the rear JE5 Caliper brackets? My Caliper pins are stuck in the bracket (rear). I'm having a hard time finding these brackets for the rear online. Most of them seem to be for JL9 set ups.
1 - 9 of 9 Posts
