I was directed to you by Kev, that you might know the part number for the GM pellets that are added to the Northstar engine coolant. Also, what type of coolant is used in the Northstar engines?
Thanks for your help.
The Bar's Leaks Golden Seal powder and Bar's Leaks large pellets are the exact same thing as the GM pellets. You can probably find the Bar's stuff at Wallymart or any auto parts store.zkmann said:I was directed to you by Kev, that you might know the part number for the GM pellets that are added to the Northstar engine coolant. Also, what type of coolant is used in the Northstar engines?
With those ingredients, it sounds like they would taste pretty good! Anybody willing to try for us? Added bonus: No more leaks! :vomit:MWA said:Ranger, I believe that PN is 3634621- GM Cooling System Seal Tabs and contents listed on the package include: ginger, almond shell, turmeric and sal soda.
I was wondering what I could use for that annoying tube snake leak.:elvis1:mcowden said:With those ingredients, it sounds like they would taste pretty good! Anybody willing to try for us? Added bonus: No more leaks!
There are multiple answers for this question. The recommended way to do it is to put the pellets or the powder in the lower radiator hose. That would, of course, assume that the system is drained. I don't see a problem with putting them in the upper hose, but others may disagree with me. I think that's easier. It's also possible you could mix it thoroughly with the first gallon of fresh coolant you dump into the system and make sure you get it all in there and it doesn't sit in the surge tank. Whatever you do, don't put the powder or the pellets in the surge tank. They won't get into the system and will just sit at the bottom of the tank and could plug up the vapor vent line causing problems.jamesmdx1 said:when should you add the powder or pellets? As you are refilling the coolant or right after the refill?...
Can you dissolve the powder in the new coolant and then add it?
thanks
