1 - 13 of 13 Posts
2005 SRX 3.6L V6. Purchased used w/ 60k miles in 2008. Almost immediately after purchasing, noticed a random hesitation at idle, felt like a misfire but never saw any check engine lights or misfire codes. As we have driven the car over the last 3 years, the misfire has gotten more frequent and severe.
Car now has 102,000 miles on it and this past month the misfire has gotten excessive. It is now setting off the engine light. I am getting random misfire codes on all cylinders. There is no ryhme or reason to which cylinder or bank it misfires on. I clear the codes, and then the next time it will be totally different cylinder(s) misfiring. Now the misfire is not just at idle, but mostly under high load partial throttle conditions while cruising. I can make it misfire just by going partial throttle, about 50-80% TPS, just enough that the tranny doesn't kick down and shift gears, thus creating a high-load situation on the motor. Almost immediately, the motor starts misfiring, and then the check engine light starts blinking indicating an active misfire, and you can really feel the car bucking too.
About a year ago at 80k miles I tried changing all the plugs. The old plugs looked fine, but I put new ones in anyways. I have swapped coils between banks and between cylinders, with no change in the pattern of misfires.
I know about the timing chain issue with the LY7 motor, and would actually be eager to identify that as the cause here, for sake of getting an actual diagnosis. It's just that I have NEVER gotten a single DTC for a camshaft or crankshaft position sensor. Only misfire codes. So, I'm wondering if maybe the chain is stretched enough to cause misfiring but not jump teeth and trip a cam/crank code? I'm not sure about this theory...
I took the car to the dealership (MotorWerks, Barrington, IL). They said it could be carbon build-up and wanted to sell me a top-end cleaning and injector cleaning. I plan on doing both these myself, but haven't done it yet. I got some GM Top End Cleaner and will follow the TSB procedure for soaking the piston rings 3 hrs and then changing oil. Will also do a fuel injector / top end cleaning using a mixture of 10%GM TEC and 90% gasoline in a pressurized canister hooked up to my fuel rail, so this should clean out the injectors and decarbonize the piston tops. I plan on doing this, but am very skeptical about it fixing the misfire issue.
As a side note - both cats on the car were replaced last fall under the EPA 5yr/80k mi warranty when I got codes about poor cat efficiency. Initially I hoped that maybe plugged cats were the culprit of the misfire, but no such luck. New cats, same 'ol misfires.
I should also add that one 2 occassions, the car has exhibited a no-start condition. Plenty of battery juice and gas, but when I cranked it would not fire. It happened once last spring, and then again this past week. It took about 4 or 5 periods of 30-seconds continuous cranking and blipping the throttle go get it to start. Once started and revved, it ran just fine, and then could be shut off and restarted normally. I am not sure what to think of this. Not bad gas, because it ran fine once started. Could this be a timing chain issue? Like where it had skipped a tooth and had intake/exhaust cams off synch, and after cranking for a LONG time, continued to skip teeth until it finally found the right combo and fired up again? Then again, if this were an intereference motor that would mean my motor should be toast too, and it's not, so that begs another question... is this an intereference motor or not? I am finding conflicting information on the internet about this.
I have read many of the posts on here about timing chain issues, and the one long thread by Brigga where he posts a video of his CTS with low-compression sounds exactly like my car did those 2 times it wouldn't start. But, then again, now that it is started, it runs "fine" except for the misfiring.
I plan on doing a compression check and leak-down test this weekend, to see if those tell me anything.
The car HAS been run low on oil a few times since I've owned it. It EATS oil alive, like 1qt per 1,000 miles. I do my best to keep it topped off, but too frequently find myself needing to add 2 or 2.5 qts to get it back full.
So my main question to you gurus out there is, does this sound like a timing chain issue or something else?
If so, I will replace the chain/gears myself using the Autozone kit. I would prefer to just tear apart the front of the motor and not take off the heads. But, then I fear:
1. Leaving loads of carbon buildup on the pistons and valves from all the "consumed" oil. And if this were the cause of the misfire, I would still have it after the TC replacement.
2. Not addressing the oil consumption issue. In Briggy's post, he mentions that the machine shop found severely worn valve guides which were the likely source of oil consumption. Obviously I would need to have the heads pulled and worked over to address this.
But... I don't want to pull the heads if I don't have to. I fear pulling head bolts on 100k+ aluminum blocks. I start getting nightmares about the TimeSert job I had to do on my 1996 Northstar... Do these LY7 alum blocks have similar issues with the threads failing?
Lots of questions I know... thanks for any/all responses.
-Jacob
'07 - 3.6l SRX RWD, '16 - 2.5l Subaru Outback, '95 - 4.3l S10 pu
Something relatively cheap you might try is cleaning the throttle body.... assuming you've not done it. On my Envoy a dirty throttle body can cause problems as you described. Be sure to disconnect the battery so the PCM can relearn.
Somewhere I've read about a no-start condition caused by buildup on the valve that keep them open. However with lower compression caused by the open valve the engine should spin over faster than normal when starting. You didn't mention that as being observed.,,, or maybe that was the case in the Brigga link you mentioned. Further I'd think you'd have to be using a steady diet of crappy fuel for this to happen.
Good luck and do let us know if you find the cause..... unlike the other post on the subject!
CTS 3.6L 2005 80,000 Miles
2005 SRX 3.6L V6. Purchased used w/ 60k miles in 2008. Almost immediately after purchasing, noticed a random hesitation at idle, felt like a misfire but never saw any check engine lights or misfire codes. As we have driven the car over the last 3 years, the misfire has gotten more frequent and severe.....
...............But... I don't want to pull the heads if I don't have to. I fear pulling head bolts on 100k+ aluminum blocks. I start getting nightmares about the TimeSert job I had to do on my 1996 Northstar... Do these LY7 alum blocks have similar issues with the threads failing?
-Jacob
dude can't believe you made me read all that ... j/k .. not really. Off the back I would.
1.) perform full service which includes
- check plugs/coils (spark gap test)
- new fuel filter
- fuel line pressure
- new air filter
2.) perform a compression test and a leak down test.
3.) if your crazy and cheap like I am you can do a drip test with the injectors. make a hose funnel apparatus and engage the injector for one minute exactly and measure the fuel which passes through. do this for all injectors to see if they are within the same range. used this to figure out what was going on with my galant and it actually worked. pulled about ten injectors from the junk yard then tested them all this way. picked the best 4 which were within the same range.
carbon build up should not cause the car to misfire, ping perhaps but not misfire. The above three test should give you an idea of where to look. also keep in mind so far most of the people who had bad timing chains received no OBII error codes. One symptom of low compression is definitely random misfires. regarding the heads failing, only one way to find out. The head bolts are all coated, if you take the time to clean out the threads (good luck finding a M11 tap) you should be fine. If you find your looking at low compression I would go ahead and replace the chain, set the timing then perform a compression test with the front cover off. If your still on the low side then your looking at impacted valves and the heads have to be rebuilt. For some reason finding guides etc built for this engine is somewhat hard. I think the dealers just replace the entire head. The machine shop I used was able to match the guides based on dimensions.
On Saturday I spent the day working on the car and accomplished quite a bit. I started with the fuel injection service. Put a shutoff valve inline on the fuel rail to cut off the fuel supply, pulled the fuse for the fuel pump, hooked up the J-tool with compressed air supply and filled the J-tool with 4-oz GM Top End Cleaner, and 16-oz gasoline. Ran the car for 20 minutes until the fuel/cleaner mixture ran out and the motor stalled. Supposedly that is the best deep-clean you can give injectors short of pulling them and and disassembling them.
Next, I pulled off the upper-intake and took out the spark plugs. YUCK! They were the nastiest I have ever seen. All 6 looked the same. Electrode tip and ground were coated with ashen deposits and very oil fouled. These photos are of the plug from cylinder #2, all plugs were identical to this.
Keep in mind that when I bought the car at 64,000 miles, I replaced all the plugs, and now we are at 102,000, so these plugs have only 38,000 miles on them. Obviously this is a result of the excessive oil consumption issue I have noted. It's either getting past the piston rings, valve-guide seals, or both.
Next, I hooked up the compression gauge and got the following readings:
1- 155 psi
2- 170 psi
3- 150 psi
4- 165 psi
5- 155 psi
6- 165 psi
That seems good to me. Looks like timing must be correct and valves are not damaged.
Next, I did the "piston-ring cleaning procedure" by putting in 4-oz GM Top End Cleaner into each cylinder. Let it soak for 3 hrs. Suck it out, and then drain the oil.
While I was at it, I also did a few more items that were due. New fuel filter (original was in, gross...), put on 2 new serpentine belts, and 2 new tensioner idler pulleys. Took throttle body off the intake manifold and cleaned with carb cleaner, but it really wasn't gunked up at all, looked surprisingly clean. Air filter was replaced 6k ago so I just left it as it was fine.
Slapped it all back together, blew tons of white smoke while the dissolved crud from the piston cleaning procedure burned off, and then took it for a drive and did about a dozen WOT blasts. NO MISFIRING! I am sure that the plugs were the culprit. But really, the plugs are more of a symptom of a greater problem, that being the oil consumption, which is the problem at heart.
I am still hearing a rattling sound coming from behind the front cover though, so I am not 100% sure that I don't have a stretched timing chain, but at least for now the car is symptom free and drives normally. For how long though is the question. How long before these new plugs get oil fouled and the car starts to misfire again?
What all is involved in changing the valve guide seals? I suppose you gotta pull the front cover, timing chains, to take off the over-head cams, and get access ot the valve-springs. Use compressed air to keep the valves supported, pull the springs, pull the valve seals, and put new ones on. Right? If so, might as well do the timing chain and associated parts while I'm in there. Briggy - do they sell just the seals? And is it the seals that are the issue or the guides themselves too? (which means pulling the heads). I am somewhat willing to give the valve seal replacement a shot to see if that cures the oil consumption issue, but there is no way I am touching the bottom end to do the rings. I'll deal with 10,000 mile plug changes and frequent oil top-offs before I go replacing piston rings.
Discussion Starter · #7 ·
@jprunty - They were replaced at 79,000 under EPA warranty. I was getting "poor catalytical converter efficiency" codes. Surely because of this...
Also, I cleaned up the garage today and before I threw out the old plugs I measured the spark gap.They had opened up to 0.060", so between the corrosion, oil fouling, and electrode deposits, it's no wonder the car was misfiring. (factory gap is .043")
SRX
Wow, that was a long list of issues. Now I've been having similar problems, but my srx its a 2004 with 80,000 miles on it. I even replaced the spark plugs around 65,000 67,000, and lately I've been having some issues with the SRX similar to yours. For one when its starts it iddles rough more than normal and I also hear a loud noise, or high pitched noised which kinda sounds like a bearing its going, I don't know, and I also has the engine light on here recently and it seems it's been burning or eating oil as well, since the other day I checked it, was lower than previously. The dealer determined there where two codes one for evap leak and a misfire code, they said they were unable to do anything since the codes were not active, as in there were no problems at the moment, it was a history of codes. So they said to take it back to the dealer if the light does comes on again. Now I've been reading a lot of things about the SRX's and I also noticed the timing chain, since you posted all this and done some work on your car already you think it might be an issue at all? Also I was thinking in looking at the plugs after you posted those pics, and a thing to mention with the plugs is when I replaced them i put E3's on it, so I might have to go back AC Delco's. Also I noticed you did the cleanng on the injectors, how hard was that to do? you have some pics or special instructions maybe? This issue has me stressed since I've read so many different things. I also did get the cats replaced back in 2008 when I received the letter from GM to get them replaced. Any help, advise and knoledge would be great.
Discussion Starter · #9 ·
Henrixroger - the high pitched whine / bearing noise you are hearing *could* be your power steering pump. I had a noise on my SRX that I would describe in that manner, and it was the power steering pump low on fluid. These cars have a known issue with the high pressure hose on the PS pump leaking fluid. There is a TSB out on it. Do a search on here, lots of info. The noise happens when the fluid level gets low. The whining noise is loudest at cold startup, and may go away somewhat as the vehicle warms up. The true fix is to replace the high pressure hose assembly. This is a couple hundred dollars and a few hours of your time. The band-aid fix to eliminate the symptoms and bearing/whining noise is to just top off your power steering fluid periodically. This is what I am doing and I've had no noise issues (that noise, lol) since. It's an easy thing to check, just look at your fluid level and top off as needed. Start up the car and see if the noise goes away.
The evap code is probably just a loose gas cap from some time ago. Reset the code, make sure the gas cap is on tight, and if the code doesn't come back, don't worry about it.
The misfire issue, coupled with the oil consumption, sounds very similar to my issue. If I were you, I would pull a few plugs to see what they look like. Just pull the plugs on the cylinders that are easily accessible without having to pull the upper intake manifold. In my case, all plugs were equally nasty. That should be quite easy to check. Just pull off the plastic enginer cover, remove a plug on coil, and take out a plug. If it is nasty, then you'll have to pull the intake manifold to get to all the plugs. I think at least 3 or 4 plugs can be done without pulling the upper intake manifold...
As for the fuel injector cleaning procedure, I'm not convinced it helped to resolve any issues, but it is something the dealership insisted on having done before moving forward with any other sort of diagnosis. I did it myself by purchasing the J-tool. I have attached 2 PDF documents to this post. One is the GM TSB on how to perform the cleaning procedure. Ignore the fact that it doesn't mention SRX, it is applicable to all GM platforms. The other is the manual for the J-tool so you can see what it looks like and how it works. Besides this J-tool, you need a compressed air source, the 90-degree elbow GM-fitting adapter for the J-tool, a fuel-supply line block-off valve (ebay for $40, the Kent Moore J37287), a container of GM Top End Cleaner, and a container of GM Vehicle Care Fuel System Treatment Plus ($30 on ebay). All these part numbers are in the attached docs.
If you are serious about wanting to do the fuel injector cleaning procedure and don't want to purchase all these specialty tools for a one time use, I would be willing to "rent" them to you to recoupe some of my cost in their purchase. Added up it's a few hundred bucks in specialty tools, but they can be used to service pretty much any GM vehicle with similar shraeder valve connections. I figured I'd rather spend the money and have the tools to show for it than pay the dealership.
SRX
I appreciate all the info. I will definitely will take those plugs out and see how they look, and may try to do the injector cleaning procedure. Also thanks for the tip about the power steering fluid, I did noticed it was lower but really never pay attention, I went and got me some fluid to put in there tonight as well as a gas cap. Again thanks for all the info.
SRX
jcobz28, Thanks for the info, i did buy a new gas cap, and top the fluid for the power steering and the winning noise went away. Now I haven't got the time to do much but this is what has happened lately, I've been getting a lot of misfires, although i'm not getting a code the check engine light just flashes and the car shakes bad. With the shaking at first it seems it was something with the transmission mainly because when I put it in reverse it started shaking and just rough shifting, really did'nt think much about it, so I decided to take it to AAMCO to get the fluid and filter change since they had a deal for $40, so when I took it there I mention the shifting and shaking and they did a diagnose or they just drove it around. The mechanic said that the problem was the torque converter, something I've never thought about, and they said they will replace it cost about $1000 plus, anyways so I decided to do the job myself, at this point the check engine light wasnt flashing or anything so I gave it a shot. After all said and done got it replaced total cost of about $250 yet it was still doing it, this time around 3rd and 4th gear when it downshifted or there was more load on the engine at this time the engine light started flashing and started shaking. Since there is no code I can't pinpoint the cylinder, but what I know is the problem I'm having its on the left bank or cylinders 2,4,6. The reason is when I pulled the ignition coil pack out on #6 the coil pack itself was really dirty full of carbon deposit, soot or whatever its called, then I pulled the plug out and in the porcelain part it seems that gases have been blowing through that plug, so I proceeded to #4, again smae color on coil pack, and same on spark plug, so I decided to remove #5 out on right bank, when I did that coil pack still looked brand new, no discoloration no carbon deposit, I pulled the spark plug and it looked just fine, nicer and cleaner thatn opposite side. So at this point my head it;s spinning, it comes back to your original post, you think it might be a timing chain issue? and why would all the ignition coil pack on left side will be so dirty compared to other side? I did try one of the plugs with the dirty igniton coil pack and put it against a metal surface and did see some spark, so can I rule out bad ignition coils? if so how can I check them? I tried checking and ohming all the connections on that thing to see the different resistance values and compared it with the good one and I had same readings, but I dont know if thats accurate or not. Now my other question, could the secondary timing chain for left bank could've jump a tooth? maybe throw the timing of the valves and just causing that blow through the plugs and plug holes? or could it be the cat? note, the cvats where replaced in 08, but maybe? Well what I'm going to try is I'm going to replace all the spark plugs and do the cleaning on the injectors, which by the way sorry I did not get back with about the cleaning tools, and also I was thinking in removing the left bank valve cover so I can see the sprockets and the aligment marks just to make sure its still timed. Any other ideas, suggestions? greatly appreciatte it.
By the way how is your car running at this point?
thanks
Discussion Starter · #12 ·
Ever since I did the injector cleaning procedure and replaced the spark plugs the motor has been running just fine. No misfire or shaking at all. Since I did both procedures at the same time I can't tell you which one was the magic fix, but I think that it was likely the spark plugs. They were SUPER NASTY (all 6) from being oil fouled. My car burns a lot of oil (has the common piston-ring oil blow-by issue these cars are known for) and it really gunked up the plugs. With the new plugs, no problems at all. Who knows how long they will last. If/when it starts to misfire again in the future, the first thing I will do is just replace the plugs. Also, I have been running 1qt Lucas oil modifier with the Mobil1 at my oil changes and it has slowed down the oil consumption - theoretically this should slow down the spark plug fouling rate as well. I know many are against oil additives, but in my personal experience it has made a noticeable difference in how much oil my engine consumes. A $10 bottle of Lucas at each oil change is a lot cheaper than a piston ring job. The car is not worth that type of investment at 110k miles in my opinion.
My recommendation to you would be to change all 6 spark plugs first before you do anything else and see if that resolves the symptoms. If not, then target the fuel injectors for cleaning next. If that doesn't work, then check the timing chains. I don't think you can check the timing by just pulling the cam covers, I think you need to pull the entire front cover, but I may be wrong - others please chime in here.
1 - 13 of 13 Posts
