So recent good weather has had the Eldo out at a time when it wouldn't be, ordinarily. I diagnosed a blend door problem, hot on one side and cold on the other, based on my readings here. And when I ran the DTCs I found B1341 "Air Mix Door Two Movement Fault" which I thought validated my diagnosis. But what really got me was everything else that came up.
P0622 Generator Field "F" Control Circuit Malfunction
B1552 Keep Alive Memory (KAM) Error
B1327 Device Power Circuit Low
B1552 BCM EPROM Checksum Error
B1983 Device Power Circuit Low
B3109 I found no definition
U1064 Loss of Communication with DIM
B2119 Lumbar Forward/Aft Sensor Failed
B2120 Lumbar Up/Down Sensor Failed
B0856 Battery 2 Out of Range
B2148 Right Front Mirror Vertical Position Sensor Circuit Low
So how much trouble am I in? Except for the rear view mirror not dropping when I am in reverse (I thought it used to do that?) I didn't think I had any problems. Am I now a menace to society? Should I expect wheels and tires to fly off at speed? How can my battery 2 be out of range, I only know of the one under the hood?
Help, please.
Help, please.
