G
Guest
·'95 Deville with OEM radio. In areas with weak AM radio signal, interference (static) occurs only below 7 miles per hour:cookoo: .
Hypothesis: When the time constant on the suspensions system changes at 7 miles per hour, the emitted interference causing the static is elimiated. "Emitted" interference is suspected because the problem occurs on a walkman radio set too.
Has anybody else experienced this problem? What can be done to reduce the effect of the interference?
