1 - 9 of 9 Posts
Just bought a 02 ext and only problem I see is that the illumination on the steering wheel on the rt side for the radio controls is out. Any way to fix this?
First time escalade owner 3 time deville owner.
Cadillac Technician
none
Replace the switch assemblies that don't illuminate.
They use LEDs soldered inside. Not worth the time and effort to even try to repair them.
The replacement ones aren't too expensive and pretty easy to replace with a few tricks.
04 Cadillac Escalade EXT
I replaced all mine when I first bought the truck pre-owned. Several were not working, was not that expensive. Might as well do them all so the finishes match. Diffrent batches made years apart might look slightly diffrent in finish.
02 Escalade
Go to The Source. They have mini lights that u can solder in, they come in packs of 2. It takes time, but isn't too dificult. I replaced every burnt out light in my truck, took a couple days on and off, but what a difference. WAY cheaper then going to the dealer!!
Cadillac Technician
none
Go to the Lindsay Cadillac section in the vendor area, make a post asking for part numbers and prices and my parts guy, Luke, will fix you up.
1 - 9 of 9 Posts
