1 - 2 of 2 Posts
2013 XTS
Dude you really should search first.
If it is like the sts there is a drain plug on the driver side under the radiator. You should be able to acess it with a socket and without removing said splash guard. Drain it fill it with fresh and drive it a couple months then do it again this way you will get the remaining coolant in the engine block flushed on the second time.
1 - 2 of 2 Posts
